Failed inspection
Old Aug 30, 2008 | 01:26 PM
frneon's Avatar
frneon
New Member
Default Failed inspection
Heres a good 1 . There is no more dino testing in Mass so I went for a Mass sticker and failed due to not getting a reading off the OBD. they told me the wires might have been cut off. When I got it home all the wires are intack with no signs of it being tampered with . I did the "ignition 3 times test" and the engine light didnt flash or turn on , and it doesnt come on when I start the neon either . Its a 1997 neon auto and its running fine other than a slight hesitation in the highway when I let off the throttle . What should I look at first ?
Old Aug 31, 2008 | 09:45 AM
12 volt's Avatar
12 volt
take it to autozone and see if there OBD tool will pull codes.
Old Aug 31, 2008 | 09:42 PM
frneon's Avatar
frneon
New Member
took it to autozone and ther scanner came up blank like its not working
Old Aug 31, 2008 | 10:17 PM
streetracer88's Avatar
streetracer88
dont take this the wrong way but after you hooked up the scanner did you turn your key forward without starting it?
Old Aug 31, 2008 | 11:20 PM
frneon's Avatar
frneon
New Member
Yep ignition was on
we even started the engine to see if it gets anything . Nope just blank
Old Sep 1, 2008 | 01:29 AM
12 volt's Avatar
12 volt
you could try getting a used PCM from the junk yard or maybe take it to the dealer and have them reflash it.
Old Sep 3, 2008 | 06:47 PM
FastNeon84's Avatar
FastNeon84
yea reflash your pcm and it should work, i had the exact same problem you did
