Horn won't blow
Old Sep 1, 2008 | 04:25 PM
PoRican's Avatar
PoRican
New Member
Question Horn won't blow
Help,
Just moved from Florida (no state inspection required) to Texas (state inspection required) and my horn don't blow. My stepdad and I tried fixing it today with no success. We moved bumper cover for easier access to front end and we only found the horn on the passenger side. There should be 2 horns, a low and a high but we can only find the one on the passenger side. We searched around the front end from above and from below and no horn on the drivers side anywhere or we just can't find it. We have current at the horn switch, at the fuse, at the relay but no beep. Anybody got any ideas?
PoRican
Old Sep 1, 2008 | 05:51 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
have you tested the horn with a 12 volt power source? if you know your horn works when you hooked it up to a power source I would think the culprit would be the clock spring in behind the steering wheel
Old Sep 2, 2008 | 10:54 AM
PoRican's Avatar
PoRican
New Member
I removed the the air bag and cover off the steerig wheel and there's a horn contact sheet which I tested and it was within specs. My main problem is locating one of the horns which I can't find. There should be a horn on the drivers side of the vehicle which should feed current to the one on the passenger side. If it's disconnected then neither of the horns will work. If I could find it then I think I can fix it.
When I removed the airbag module I saw the clockspring. What's it's purpose?
Thanks for your help.
Old Sep 2, 2008 | 04:08 PM
DOHCgarrett t3
the purpose im not sure i know if they go bad either the Horn wont work or the CC goes out. Das would be able to tell you specificly what it does.
other than that im not positive but i think there is only one horn.
Old Sep 2, 2008 | 05:51 PM
bone33's Avatar
bone33
just rig an aftermarket horn to the wiring and forget about the horn that you cant find. a horn is a horn and you will pass inspection.
Old Sep 2, 2008 | 07:50 PM
12 volt's Avatar
12 volt
since you cant run wires thru the joint were the wheel truns, since they would just get twisted up. So you use a clockspring, this allows you to transmit the signal you need thru a movable joint.
i would have to check my car to find the horn and i dont have it with me curently.
