I need help with my Neon money pit.
Old Sep 5, 2008 | 04:34 PM
Stupidcar's Avatar
Stupidcar
New Member
Default I need help with my Neon money pit.
Hello everyone.
I have finally beat my cooling issues atlast! Now the car surges and generally runs crappy and I have a check engine light. the codes I get are 12 (I read that that is kinda normal) and 24. This isn't the first time I have had these codes pop up. The first time I simply removed all the corrosion form the battery leads and reset the computer and like magic the car ran fine for about 200 miles. Well the codes are back and I realy don't know what to do about them because I hate throwing money at a probelem that I'm not sure about. I'm leaning towards changing the TPS. What do you all think?
Thanks
Old Sep 5, 2008 | 06:57 PM
95sprtcpedrvr's Avatar
95sprtcpedrvr
Don't change the TPS just yet.
If you can get a scanner and get me the actual diagnostic code I can help you. I'm looking for a code that is either a; P0121, P0122, P0123, or P1295. Otherwise your going to have to use a multimeter to check to see if you're getting voltage to and from the TPS and the resistance range throughout the throttle movement.
Old Sep 5, 2008 | 07:04 PM
neoncrazy101's Avatar
neoncrazy101
just go to Autozone and they can read the code and get you the Pxxxx code. that is unless your car is a 95.
Old Sep 5, 2008 | 07:05 PM
95sprtcpedrvr
You should be able to pull a code even if it is a '95.
Old Sep 5, 2008 | 07:16 PM
neoncrazy101
they wont look it up though at Autozone nor Advance because its not the newer computer type like the other Neons. sry i'm having a brain fart and cant remember what its called lol.
Old Sep 6, 2008 | 08:53 PM
eaks's Avatar
eaks
OBDII is the 96 newer Any OBDII scanner will give you the pxxxx codes your looking for!
Old Sep 6, 2008 | 09:00 PM
dhvaughan's Avatar
dhvaughan
won't autozone also have an OBD I code reader for 95 and back ? i thought they did.
Old Sep 6, 2008 | 09:20 PM
neoncrazy101
they should. but they dont scan them. least none around here in Columbus.
Old Sep 7, 2008 | 10:57 AM
spudsterier's Avatar
spudsterier
95 neons are aslo OBDII....if the autozone seems like it will give you a problem, just tell them your car is a 98
Old Sep 7, 2008 | 02:07 PM
neoncrazy101
hey Spud, i thought the 95's were OBDI but also OBDII backwards compatible? oh well.
