1999 Neon grinds in second gear....
Old Sep 16, 2008 | 05:13 PM
HawgDaddy's Avatar
HawgDaddy
Default 1999 Neon grinds in second gear....
Ok, thanks in advance.... I have a 99 neon manual shifter. I have read the earlier posts and have a quick question. It grinds in second gear either up or down shifting. I have heard syncronizers, or forks could be the problem. Either way, I don't work on transmissions. I hear a used transmission is cheaper than a fix. True? The only work I know that was done prior to me getting the car was that it did have a clutch cable replaced at one time. Could this be part of the problem?
Also, how do I know if I have a conventional or modular clutch?
Old Sep 17, 2008 | 10:55 AM
das2123's Avatar
das2123
You have a 99 so if your vin starts with a 1, then you have a modular clutch.
You can find a used tranny from about $75-$200. So many times it is quicker and easier to replace the tranny.
