misfire
Old Sep 16, 2008 | 09:18 PM
clb2801's Avatar
clb2801
Default misfire
i have a 97 neon that started misfiring.
it only does it at 1500 to 2500 rpms and at around 5000 rps.
its idling fine and the wiers and plugs are new.
im thinking the timing belt but it looks fine.
this has got me stumped
Old Sep 16, 2008 | 09:52 PM
das2123's Avatar
das2123
Misfires can be alot of things....do you have any codes?
Old Sep 16, 2008 | 10:05 PM
clb2801's Avatar
clb2801
ill check again but....
i took it for a drive and when it misfired i tried to give it gas and a snap sound came from the front right side and it now dosnt idel so smooth lol it pops here and there so maybe it is the timing belt
Old Sep 16, 2008 | 10:17 PM
clb2801's Avatar
clb2801
nothing new, just code 21 thats been there for years
Old Sep 16, 2008 | 10:35 PM
clb2801's Avatar
clb2801
any help would be great
Old Sep 17, 2008 | 08:20 AM
das2123's Avatar
das2123
Did you check the coil pack? Make sure it doesn't have any cracks and clean the leads if you have to. Check all you battery connections to make sure they are clean and tight.
Old Sep 17, 2008 | 12:47 PM
12 volt's Avatar
12 volt
pre cat o2 sensor?
