what size ?
Sep 28, 2008 | 12:19 AM
what size ?
I have a 95 plymouth neon sohc and im trying to think of what size exhaust i should go with...2.5 or 3.0 in ?And the car is stock
Sep 28, 2008 | 05:19 AM
on a stock motor...just go with 2.5, upgrade to 3'' when u do forced induction or NA build up
Sep 28, 2008 | 11:53 AM
hell on a stock car, its a waste of money to upgrade the pipe diameter
Sep 28, 2008 | 02:00 PM
isnt the stock size 2.5''? or is it 2.25''?
Sep 28, 2008 | 02:31 PM
Stock is 2.25 I believe, which is plenty for a neon. Hell I only have a 2.5" pipe on my built camaro...
Sep 28, 2008 | 09:43 PM
when i get my new header it has a 3 in collector so i decided to go with a 3 in exhaust do you guys think thats to much?
Sep 29, 2008 | 10:38 AM
ummm..yeah....if they pipe is too bit it will rob you of power just the same as if the pipe was too small....
3" pipe shouldnt be used unless the car is fully modified and running a huge turbo....
even on my fully built turbo r/t i was only running 2.5"
Sep 29, 2008 | 02:47 PM
Quote:
Originally Posted by
streetracer88
When you get your new header, save the money on the exhaust piping and use it elsewhere, where it will help.
Sep 29, 2008 | 08:00 PM
ok so i guess i will go with a 2.5 in exhaust instead of a 3 in collector thanks for everyone's help
