Painted intake manifold
Old Nov 2, 2008 | 01:52 PM
neonracer1010's Avatar
neonracer1010
Originally Posted by spudsterier
the 1 you have also had alot of gas spilled all over it numerous times
and its slightly ported
Old Nov 2, 2008 | 03:47 PM
12 volt's Avatar
12 volt
powder coat FTW
Old Nov 3, 2008 | 01:04 PM
fsu182's Avatar
fsu182
did mine in flat black rustoleum. looked nice. as appose to stock - which gets oil and dust stained. i didnt even use high heat stuff and it stuck, stayed, and looked great.
Old Nov 3, 2008 | 03:29 PM
das2123's Avatar
das2123
Polishing the aluminum intake manifold looks real nice.
Old Nov 4, 2008 | 10:23 AM
oobical's Avatar
oobical
I painted the plastic intake parts on Ford Trucks before, sorry for using bad language but the Neon is my first Dodge. Intakes are made from ABS, Rubber, Aluminum or Stainless usually. The ABS intakes are the easiest if you dont have the ribbed tube (The tube with all the ridges in it) Just clean the surface with some kind of parts cleaner that doesnt leave a residue behind, sand the entire surface to ensure that the primer will stick. Use a primer and sealer, i usually do 2-3 coats and then cure for 20-30 minutes in between coats and follow the next day with 2 coats of base color and let cure for several hours and then coat with 1-2 coats of clear and it will be very glossy after the finished product comes out. if you want flat leave the clear coat off. if you are looking for easy cleanup from oil and dirt go with the clear.
Old Nov 4, 2008 | 10:26 AM
das2123's Avatar
das2123
^^^He is talking about painting the intake manifold, not the air intake tube.
Old Nov 4, 2008 | 11:40 PM
oobical's Avatar
oobical
sorry only read the first couple words, i already painted mine. i have a SOHC Neon and what I did was washed the intake in a parts washer let it dry under a fan and blocked up the holes. VERY IMPORTANT TO MASK ALL HOLES AND ANY PLACE WHERE A GASKET GOES! I used high heat primer and paint, did not clear coat and it looks fine, I will add some shots when I pull the motor to replace the mounts of the finished product.
Old Nov 5, 2008 | 08:26 AM
das2123's Avatar
das2123
^^^You don't have to pull the motor to replace the mounts.
