small problem....help me out
Old Oct 14, 2008 | 09:33 AM
99 Neon's Avatar
99 Neon
Default small problem....help me out
so im not sure of the exact car terminology to use so ill just use kindergarten vocabulary. If your standing in front of your car right below the fuse box slightly to the left theres a cable and at the end of the cable (on mine because im missing a part) theres a big circle loop (about the size of a half dollar coin) and this circle connects to a small little part so your standard car can shift gears. Now heres my problem... my big circle will slip off of this small part that it connects to and it will result in me not being able to shift at all. You guys know what im talking about? Anyone got one? because my mechanic said that part would cost 150 dollars and i was like eff that.
Old Oct 14, 2008 | 10:37 AM
spudsterier's Avatar
spudsterier
sounds like you need new shifter bushing
Old Oct 14, 2008 | 01:14 PM
99 Neon's Avatar
99 Neon
its the up and down shifter cable its missing a piece thats why it just slips off all the time. the mechanic says i need an entire new shifter cable. do i?
Old Oct 14, 2008 | 09:34 PM
spudsterier
the bushings arent available through most parts stores and the dealerships sell only the cable...but go to boogerracing.com then click on order page on the laft of the screen.....the bushing are only $22 shipped and are well worth the money
Old Oct 14, 2008 | 11:05 PM
JDAWG901's Avatar
JDAWG901
Smile
i have wanted to swap out my bushings .can you fell the difference from the factory ones
Old Oct 15, 2008 | 10:14 AM
spudsterier
deffinately....the difference is amazing
Old Oct 19, 2008 | 09:21 PM
99 Neon's Avatar
99 Neon
thanks spud. hope its the right thing i need. it would save me a good 100 dollars than
Old Oct 20, 2008 | 09:50 AM
spudsterier
not to mention you can put the bushings in yourself with just hand tools and dont have to take it to a shop
Old Oct 20, 2008 | 12:04 PM
99 Neon's Avatar
99 Neon
please explain...i bought them last night...should be here in a week or so. right now i have a tie down holding down my shifter cable so it doesnt come loose
Old Oct 21, 2008 | 02:14 AM
spudsterier
all you do is push the old pushing (if they are still there, 1 of your isnt) out of the cable ends...you can usually do it with your hands or pry it out with a screwdriver....then just slide the new bushings in and they basically clip onto the shifter arm on the trans..
i wouldnt even worry about changing the bushings on the shifter handle....it will really stiffen the shifter up, but the stock ones usually dont go bad there
