neon codes help
Old Feb 7, 2005 | 01:52 PM
juanmanuel's Avatar
juanmanuel
Default neon codes help
im from mexico city... i have some problems with my neon 95 and i dont know how to solve it...but i dont understand the problem that it has... my car led 25 and 31 codes .. in the board but i dont know.. how can i tell to the mechanic what it has ...i put an exhaust like for a year... it had a good sound but now it doesnt sounds.. i dont know what can be.. i replaced the exhaust tube .. and doesnt sounds too and it consumes a lot a lot of gasoline.. i dont know if u can help me to solve this... thanx
what i have to do to solve the problem
Old Feb 7, 2005 | 04:17 PM
techmanbd's Avatar
techmanbd
Default RE: neon codes help
Here
https://dodgeforum.com/m_126008/tm.htm
or here
https://dodgeforum.com/m_63384/tm.htm
Old Feb 7, 2005 | 06:55 PM
juanmanuel's Avatar
juanmanuel
well thanx i know that list... but i dont know what does that means..
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
31 Evap purge flow monitor failure or evap solenoid circuit
what do i have to do to solve the problems... where are they.... thanx again
Old Feb 8, 2005 | 05:16 AM
ewetho's Avatar
ewetho
try looking at all th hoses to an from tour intake manifold for a hole. then reset everything and see what comes back. may be hole, crack, disconnected hose from evap system to intake.
