my fuse pump fuse keeps blowing i need help bad
ok so i have a problem and need help asap i have a 98 neon sohc 2.0 auto trans my fuel pump fuse keeps poppin on my and i dont know whats going on i have replaced my fuel pump relay and my fuel pump its self egr valve crankshaft position sensor (due to code) and my throttle position sensor and it is still blowing fuses. now it dont matter if its hot cold, sunny or snow. long drive or short it can do it i can replace the fuse and be good for the rest of the day other times i will do it and blow three befor it even starts then a mile or two down the road it will blow again. now behind my battery under the fuse box there is a ground wire i thought my be the issue but playing with that dont seem to help much either. any ideas?
ok so i looked at it.. again in not really sure as to what im looking for but the wire to the top side of the o2 seem to be ok and the wires goin to the plug part seem to be ok do you think anything with the oil sending unit wires have anything to do with it cause lookin at the o2 i saw one wire goin to the o2 sensor and the end goin to the plug was kinda bare.....
