Manual won't shift into 1st!!!
Old Feb 11, 2005 | 05:09 AM
DU571N's Avatar
DU571N
Default RE: Manual won't shift into 1st!!!
I had the same problem with my Car... It is totally your syncros... the bad news is First and Second Gear syncs are not excatly servicable... you will need a new assembly... if it was 3 rd gear it would be diffrent as you can just pop it out and put a new one on... I don't even thing you can get the parts seprately. ( I couldn't ) I hope I am wrong though cause it was a expencive repair...
