will these?
Old Nov 4, 2008 | 10:13 PM
streetracer88's Avatar
streetracer88
Default will these?
fit on my 95 plymouth neon without rubbin 195/70 r14's?my struts are bad so yah the car sits a little lower but i didnt lower it any one know if it will rub?
Old Nov 4, 2008 | 10:26 PM
neoncrazy101's Avatar
neoncrazy101
those tires will most likely rub. their wider and taller.
Old Nov 4, 2008 | 10:48 PM
streetracer88
ok thanks alot i was bout to buy them for cheap lol.. $150 for them and they were winter tires with almost brand new tread still had the nipples on them i thought i would ask first before i got them tomm but know i hold out thanks
Old Nov 4, 2008 | 10:57 PM
neoncrazy101
np man. if u want to make sure of no rubbing, but like the 195 series stance, then go with the 195/60/r14s. its what i have and no problems. from what i have learned. every +10 on the first number (185, 195...) go down 5 on the second. like the OEM is 185/65. with the 195's go with 195/60's. and you should be fine.
I actually have Fuzion HRi 195/60's and i like them a lot.
Old Nov 6, 2008 | 01:20 PM
GLXRustang's Avatar
GLXRustang
FYI I am running Sumitomo 205/60 R14's on the alloy wheels without rubbing.
Old Nov 6, 2008 | 01:25 PM
das2123's Avatar
das2123
The 70 tire would be too wide.
Old Nov 7, 2008 | 08:44 AM
GLXRustang's Avatar
GLXRustang
the first 3 numbers are your section width in MM's. The second set of numbers is the aspect ratio. For example:
P225/ 50 R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
This from the Tirerack.com
http://www.tirerack.com/tires/tirete....jsp?techid=46
Does this solve the confusion?
Old Nov 7, 2008 | 11:56 AM
streetracer88
would these rub? 205/55 R16 ?
Old Nov 7, 2008 | 12:06 PM
das2123's Avatar
das2123
Shouldn't rub. I know a couple of people running that size and have no problems.
Old Nov 7, 2008 | 12:12 PM
streetracer88
yah cuz i can pick up a pair of 16" snows for the front for $150 on 2 rims but then i would have to find another pair of the same rims to make it look right
