headgasket?
Old Nov 5, 2008 | 07:22 PM
streetracer88's Avatar
streetracer88
Default headgasket?
How much does it cost to get a headgasket replaced mine isnt bad but its around that time to get 1 for preventive maintence give me a rough estimate thanks
Old Nov 5, 2008 | 10:11 PM
12 volt's Avatar
12 volt
$300 ...
Old Nov 5, 2008 | 10:21 PM
streetracer88
thats all said and done $300?
Old Nov 6, 2008 | 06:08 AM
grswat's Avatar
grswat
Depends on who you have do it. Shop will prolly want between $600 and $1000. parts themselves would probably be $200-$300 assuming you are getting a head gasket set and new timing belt/water pump. Takes me about 4.5 hrs to do it and most shops charge $80/hr so figure $300ish in labor.
Old Nov 6, 2008 | 03:34 PM
streetracer88
yea i just recently replaced my water pump and timing belt so i wont have to buy them again then right?
Old Nov 8, 2008 | 08:28 AM
grswat's Avatar
grswat
Depends on your definition of "just". If its over 40k miles I would replace them again. You probably don't need to but whoever is doing it will have the belt off and the pump is just a couple bolts away so there's no use in putting old parts back on.
Old Nov 8, 2008 | 02:38 PM
streetracer88
they have less then 1500 miles on them
