timing question
Old Nov 15, 2008 | 12:55 PM
chief135smitty's Avatar
chief135smitty
Default timing question
When I put the tensioner back on and rotate the engine two revolutions my cam pulleys are always 1/2 tooth off. Should the crank start 1/2 btdc and then finish at tdc when the tension is applied? Is there a trick to timing because it seems that if I am 1/2 off on the cam pulleys then I move the belt one notch that would be to much of a correction. This is very frustrating, there must be some trick to this?
thanks for your input
Old Nov 15, 2008 | 01:19 PM
12 volt's Avatar
12 volt
maybe this will help
Set the crankshaft sprocket to TDC by aligning the sprocket with the arrow on the oil pump housing, then back off 3 notches before TDC.
Set the camshaft timing marks together by aligning the notches on the sprockets.
Rotate the crankshaft 1/2 tooth counterclockwise from TDC.
Install the timing belt in this direction. Starting at the crankshaft, go around the water pump sprocket, idler pulley, camshaft sprocket(s) and then around the tensioner pulley.
Move the crankshaft sprocket to TDC to take up the belt slack.
http://www.autozone.com/shopping/rep...00c1528007905b
https://dodgeforum.com/forum/showthr...highlight=neon
