Burnt????
Old Nov 21, 2008 | 06:25 PM
streetracer88's Avatar
streetracer88
Default Burnt????
why would my tranny fluid be burnt?Its as dark as dirty oil and i just put fresh fluid in a month ago...any help??
Old Nov 21, 2008 | 06:45 PM
HellaciousHemi's Avatar
HellaciousHemi
Could be over heating, put an auxillary cooler on it if you think it is running hot. Is there any slipping going on?
What exactly is it doing while driving? Shift firm? vibrations? odd noises? shift soft? delayed shift?
Old Nov 22, 2008 | 12:59 PM
streetracer88
delayed shift sometimes delayed hard shift but the car only has 67k on it..so idk i changed the tranny filter before and it stopped for a while but now it started again
Old Nov 22, 2008 | 10:35 PM
Nates_expresso's Avatar
Nates_expresso
I drive sticks because I hate a system designed to fail without easily replaceable parts. My thought process is as follows, but keep it in mind I really dont know whats up with autos.
It was doing this before you changed fluid and filter. Did you cut up the old filter to see what was inside it? If not, it doesnt matter anyways, but it does give an indication to what's up with your trans.
It stopped for a while, which means to me, that it cleaned some clutch pack particles out. It started up again, so imho that cleaning clogged your filter. If you used a good synthetic of your choice, i bet it cleaned alot of stuff out and clogged your filter a bit (you changed that right?)
Anywho, changing the fluid and filter is cheaper then a new trans (which you'll need to buy new for anyways)
Changing it again cant hurt anything more, no matter what the reasoning is, the solution (or wa$te of time). Most ppl will suggest it. Do it and see if that helps anything. Mabey the bands need adjusting or some **** too, but I dont have a blues clue about that crap...
~Nate
Old Nov 23, 2008 | 06:45 PM
streetracer88
yea i think im going to change the fluid and filter and see if that helps any thanks for the help
Old Nov 25, 2008 | 09:39 AM
das2123's Avatar
das2123
How's your fluid level?
Old Nov 25, 2008 | 04:22 PM
HellaciousHemi
Get a transmission service done on it. They use a cleaner which is done by driving it around for a short time. Then they hook the machine up to remove and install fluid. Then they should be adding a conditioner. If you can't afford that I am sure you can figure out a plan on servicing it.
The filter you may have used could be felt which clogs up easily. Then again I am not sure if they produce that type of filter material anymore for transmissions. Make sure its the correct fluid also when you change it again. Firm shifts do not necessarily mean it is bad or operating incorrectly. If its a harder shift then you might want to do some diagnostics w/ fluid condition & computer.
If this doesn't help, try and see if the band(s) need adjusting (like mentioned prior) IF you can even adjust these transmissions.
Old Nov 25, 2008 | 04:49 PM
streetracer88
i got a tranny flush done on it and it is fine so far i think the filter got clogged thanks for everyones help
