starter wont turn off
Old Dec 9, 2008 | 03:57 AM
snunicycler's Avatar
snunicycler
Default starter wont turn off
i replaced my starter (and my negative battery cable cause it looked like crap) and when i went to start the car, it turned over, started for a few seconds, and died but the starter kept humming/buzzing. i had to disconnect the battery. it got dark so i will try again tomorrow but does anyone know what my problem could be? do i have a short or something? do i have my wiring messed up? one wire can only go in one place and one way but there are two wires( one ground and one that goes to the battery) that connect to a bolt on the starter. would it matter if i put them on in the wrong order? i may have done that. i cant remember how they were. any help is greatly appreciated. thanks!
Old Dec 9, 2008 | 08:14 AM
GLXRustang's Avatar
GLXRustang
I've heard of solenoids sticking, was this starter brand new, reman, or j-yard? Either way, you'd want to check the wiring in the day, next time it happens try tapping the solenoid or starter with a hammer to try to free it up if it was stuck.
Old Dec 9, 2008 | 08:58 AM
snunicycler
refurb from auto zone. i'll see what i can do. thanks!
Old Dec 10, 2008 | 09:28 PM
das2123's Avatar
das2123
Definitely check your wiring and make sure its grounded.
Old Dec 10, 2008 | 09:34 PM
12 volt's Avatar
12 volt
try swaping the horn relay withe the starter one
Old Dec 11, 2008 | 08:37 AM
GLXRustang's Avatar
GLXRustang
Yeah thats good since relays can stick too, if its stuck, your horn will go off!
