high compression?
Old Dec 13, 2008 | 05:19 PM
99r/tneon's Avatar
99r/tneon
Default high compression?
what is the limit on high compression before the motor wont run on pump gas?
Old Dec 13, 2008 | 05:33 PM
12 volt's Avatar
12 volt
the limit would be the ponit where it starts detonate (ping knock)
Old Dec 13, 2008 | 06:24 PM
99r/tneon's Avatar
99r/tneon
lol no **** haha what i'm getting at is like i aint tryin to buy pistons and put it all together and have to run race fuel ya know
Old Dec 13, 2008 | 10:45 PM
I_Ride_Neon's Avatar
I_Ride_Neon
It depends on a few factors. I heard the highest you can do on street fuel is between 10.5:1 and 11.0:1 But dont quote me. You can also shave down the head to drop the compression also. What are your plans?
Old Dec 14, 2008 | 12:15 PM
99r/tneon's Avatar
99r/tneon
yes, i know about decking the head. i ordered a mopar per computer, i'm getting a nice set of crower cams and wanted to go like 10.5 or 11 compression but i want to stay on pump gas
Old Dec 14, 2008 | 04:43 PM
I_Ride_Neon
I ran 10.5:1 on my sohc, with mopar ecu, udp, no a/c or p/s, then afew other basic bolt ons. I beat my cavy that ran 15.2. I was impressed. Anyways. I wouldnt get the mopar ecu if you plan to run all motor. Go with af/x? Higher rev limiter and more advance timing. Then go with the 10.5 pistons with a slight deck on the head. Run 92 or 93 octane. Maybe a small shot of nos is in order. Dont forget do upgrade your valve train.
Old Dec 14, 2008 | 05:12 PM
neoncrazy101's Avatar
neoncrazy101
Just to expound a little. Dont get the Mopar PCM if you want to go turbo. if your going NA though its fine for a mild build. if you want extreme go with AF/X or if you really want to, go with mega squirt.
Old Dec 14, 2008 | 11:04 PM
99r/tneon's Avatar
99r/tneon
i ordered the mopar computer, waiting for it to come in, i'm also ordering crower cams. i want to go high compression so no need for any other type of computer.. i just really dont want to run anything other than 93.
Old Dec 15, 2008 | 09:48 AM
das2123's Avatar
das2123
I think by saying he is wanting higher compression, that turbo is not in his plans. If that were the case, then he would want to lower his compression.
Old Dec 15, 2008 | 10:56 AM
neoncrazy101
Yeah I know i just wanted to expound for other people just in case they wanted to go turbo.
