srt-4 motor swap help
Old Dec 14, 2008 | 01:06 AM
apolahar08's Avatar
apolahar08
Default srt-4 motor swap help
hi i have a 95 neon sohc 5 speed and i am looking to swap out motor for the srt-4 motor. could someone tell me what i all need to buy and do to make it fit. can i use my trans. that i already have in the car?
thanks
Old Dec 14, 2008 | 02:42 AM
12 volt's Avatar
12 volt
Q: What do I need to get the SRT-4 engine in my 1st gen?
A: You will need the engine, a 2.4 side motor mount adapter, wiring harness, and a NEW PCM that has not seen sentry, unless you are ready to swap the sentry stuff over also. You can eliminate the PCM and run the engine using Megasquirt. Don't know what that is, Google it!
Old Dec 15, 2008 | 12:44 PM
apolahar08's Avatar
apolahar08
can i use my old trans. it is manual. where can i buy all of the mounts like the side motor mount adapter? and what is the sentry mean?
Old Dec 15, 2008 | 01:18 PM
12 volt's Avatar
12 volt
i cant remember if you can still use the trans, thow i think you can by swaping the bell housing or something someone correct me if im wrong.
Side mount
http://www.modernperformance.com/pro...oducts_id=1436
Sentry Key® or Engine Immobilizer
Old Dec 16, 2008 | 05:32 PM
Slo_neon_90's Avatar
Slo_neon_90
lfmao + one on that sentry key question
i'm doing a tru srt-4 swap myself.
if i'm running MS do i need to modify the harness and were can i get the harness can i just buy one from anywere or do i have to get it from the donor car?
Old Dec 16, 2008 | 10:46 PM
12 volt's Avatar
12 volt
you can cut up your old one or make a new one
Old Dec 19, 2008 | 11:58 AM
das2123's Avatar
das2123
Read up....
https://dodgeforum.com/forum/1st-gen...e-nv-t350.html
