Possible PCM failure
Old Dec 28, 2008 | 04:57 PM
vlmuke's Avatar
vlmuke
Default Possible PCM failure
Yesterday when I was driving to work in my 97 neon DOHC it just died coasted to a stop and tried to start it back up just cranked towed it home and I'm getting no spark and no fuel I swapped the ASO relay with the horn relay it does work then hooked up my code reader to see if it threw any codes reader can't connect with the computer tried it several times no luck any suggestions?? Did my PCM take a crap on me?
Could it be the crank sensor or camshaft sensor?
Thanks
Rich
Old Dec 28, 2008 | 09:09 PM
vlmuke's Avatar
vlmuke
reset computer, still scanner can't connect with computer tried turning key on and off way but nothing not even code 55
not sure what to do its winter and I need my car fixed as its my only car
Thanks
Rich
Old Dec 28, 2008 | 11:32 PM
das2123's Avatar
das2123
Do you hear the fuel pump prime? Check your battery connections to ensure they are clean and VERY snug on the battery posts.
Then check the crank and camshaft sensor.
Old Dec 29, 2008 | 11:43 AM
vlmuke's Avatar
vlmuke
No I get nothing from fuel pump or spark
Thanks I will check them and let u know
Old Dec 29, 2008 | 12:45 PM
das2123's Avatar
das2123
Do you get your cabin lights to come on when you put the key in?
Old Dec 29, 2008 | 01:04 PM
vlmuke's Avatar
vlmuke
yeah the cabin light lights come on car cranks OK no spark or fuel when I was going to work it was flooded and really rough from all the ice melting my code reader can't connect with computer and I swapped out the horn relay for the ASO relay in case it was that I'm thinking either the crank sensor or the computer but only have the money to replace one or the other right now it also would stall alot when the engine was cold but would be fine once the engine was warm I don't know it its related or not
Thanks
Rich
Old Dec 29, 2008 | 05:28 PM
vlmuke's Avatar
vlmuke
OK went to the bone yard and got a used computer don't know it it works or not, put it in still the same thing no codes no spark or fuel ???? any suggestions
Thanks
Rich
Old Dec 29, 2008 | 11:48 PM
das2123's Avatar
das2123
Fuel pump fuse?
Old Dec 30, 2008 | 10:24 AM
vlmuke's Avatar
vlmuke
is that the one in the black box under the hood I checked it and it was good but what about the scanner not being able to connect to computer? it still should do that on either one
