busted head bolt
Old Dec 30, 2008 | 04:27 PM
djberneski's Avatar
djberneski
Default busted head bolt
how can I retrieve a busted head bolt from the block, I didn't know that the bolts are torque yielded
Old Dec 31, 2008 | 01:30 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
I think you will have to remove the head entirely to remove the bolt. it should come out pretty easy if it is not snaped below the block.
Old Dec 31, 2008 | 02:38 PM
djberneski's Avatar
djberneski
the bolt broke off below the block. What is the best way to get it out
Old Dec 31, 2008 | 03:37 PM
12 volt's Avatar
12 volt
EZ out depending on how deep it is
http://www.brokentap.com/easy-outs.html
http://www.dimebank.com/tech/BrokenBolt.html
http://www.hvacr-tools.com/mm5/merch...EXTRACTORTOOLS
if worst drill it all out and helicoil it back together
