dang struts!
Old Dec 31, 2008 | 11:42 AM
neoncrazy101's Avatar
neoncrazy101
Default dang struts!
so I finally got my KYB's and I'm attempting to take the strut mounts off the old struts but I cant seem to get the shaft nut off! It just spins the metal shaft of the strut. I noticed in the FSM that theres a special tool that you can use to get the shaft nut off and then put a 10mm on top of the shaft to keep it from spinning. But I dont feel like spending $90 for the tool. so any idea's on how to keep it from spinning?
Old Dec 31, 2008 | 03:02 PM
Nates_expresso's Avatar
Nates_expresso
Beg borrow or steal an impact wrench.
If not, I think it's a 10mm hex on the end of the shaft, and the nut's 21mm. With some frustration it will come off, or you'll ball tap yourself with the 21mm when the head shears off the strut. Get an impact...
Put your old mount on the end of the shaft upside down, and try to flex the bushing. See if it's worth keeping or not (i'll guess not)
~Nate
Old Dec 31, 2008 | 03:38 PM
neoncrazy101
Yeah I got it. a 13/16s spark plug socket with a 10mm 1/4" socket inside with extensions going through it and then through some adapters and then onto my impact... it came off lol. just stubborn as ever.
Old Dec 31, 2008 | 03:48 PM
Nates_expresso
new mounts with new struts, or you reusing your old ones?
Old Dec 31, 2008 | 05:42 PM
neoncrazy101
reusing them. they all seem fine.
Old Dec 31, 2008 | 06:52 PM
Nates_expresso
i'm sure you're done allready, but I bet if you flipped them over and put some force on them you'd see the bushing pulling away from the rubber. It's only a melted rubber connection, they dont last the greatest...
~Nate
