97 Neon won't start
Old Dec 31, 2008 | 06:31 PM
vlmuke's Avatar
vlmuke
Default 97 Neon won't start
OK my 97 neon won't start turns over just fine timing belt OK fuses OK I was having issues with possibly bad PCM got a known good one out of a 98 put it in, found the ignition fuse on the dash blown replaced it got a signal from PCM fuel pump kicked in and turned car over ran for a second then died now back to square one no signal from PCM no fire no fuel but now the fuse isn't blown any suggestions I am really frustrated
Thanks and Happy New Year
Rich
Old Jan 1, 2009 | 02:59 PM
JesseP's Avatar
JesseP
Im having kind of the same problem, the relay for my fuel pump wasn't receiving power, had to rewire that. And now my ignition coil isn't getting power... Trying to figure out why... Mine would turn over and everything too, just wasn't getting fuel.
Old Jan 1, 2009 | 05:01 PM
vlmuke's Avatar
vlmuke
I looked at the manual and I'm gonna check the crank sensor if that doesn't help gonna check the cam sensor but from what the book said I think its the crank sensor you might want to do the same
Old Jan 1, 2009 | 05:45 PM
JesseP's Avatar
JesseP
Aight mine turns out to be the computer, I don't know if you have tested yours or not, but if u cant figure anything else out might wanna try that.
