Need help! No spark...
Old Jan 24, 2009 | 08:15 PM
streetracer88's Avatar
streetracer88
that must be what happened keep us posted thanks
Old Mar 16, 2009 | 04:13 AM
HOWFAKE's Avatar
HOWFAKE
Hey guys i know its been a while...but ive been busy with other crap! Buuuut ive found the reason to the problem!
Its on of those crazy occasions but the problem was the flywheel was disconnected from the crank! It broke off the weld in the center so the only thing the starter was spinning was the flywheel, around the crank.i found this out by finally getting tired of not finding the problem electrical wise...so i went back to step 1 checking compression and got 0% on all cylinders...lifted the car up and found the flywheel cover off...spun the flywheel with my finger!!! Not good...the car did have a problem with the pulley running the belts off...my guess is with that unbalanced stress and maybe the fact that the crank was hot,then getting splashed by the cold water,it just gave out!
I guess its time to replace the short block!
