Oil in spark plug well/smoke out exhaust
Old Jan 20, 2009 | 01:51 AM
gangsta_money23's Avatar
gangsta_money23
Default Oil in spark plug well/smoke out exhaust
On my way home from work a few weeks ago my 95 neon decided to start smoking out the exhaust, smelling very bad, and also running like ****. I got home an checked spark plugs and there was oil in at least one of the wells. So I'll be replacing the valve cover gaskets as well as the plug well o-ring seals. But would the smoke have been coming from that or do I have a whole seperate issue with that? Thanks
Old Jan 20, 2009 | 07:53 AM
das2123's Avatar
das2123
What color was the smoke?
Old Jan 20, 2009 | 12:05 PM
gangsta_money23
it was grayish i think, there wasnt a ton just enough that i could see that it was smoking. might've been a lighter balck as well.
Old Jan 20, 2009 | 12:25 PM
bad venge's Avatar
bad venge
Section Moderator
It could have been oil burning off the engine /plugs and the smoke running underneath
Old Jan 20, 2009 | 12:37 PM
GLXRustang's Avatar
GLXRustang
I would check your plugs as well. If they are black and wet then you got an oil foul prob. Pray that those gaskets fixed the leak..
Old Jan 21, 2009 | 07:36 PM
streetracer88's Avatar
streetracer88
i think the smoke is just the oil burning off of your plugs so look at them and see if there still good if not after you replace the gasket set replace your plugs and you should be good and it ran like crap cuz oil in the plugs not getting a good spark
