a couple of questions????????
Old Jan 20, 2009 | 07:21 PM
slo_neonRT's Avatar
slo_neonRT
Default a couple of questions????????
i just bought the dis2 msd ignition and have no idea where to mount it under my hood if any one can tell me where u put urs or no where to put it it would help big time also i wanna no wut a bone stock srt-4 tops out at
Old Jan 20, 2009 | 10:50 PM
spudsterier's Avatar
spudsterier
if i recall the stock srt4's top out at sumwhere between 130 and 150mph but im not completely sure.....i got an old friends srt4 up to 155mph on a back road once, but it wasnt stock either..
most people i see using the dis box just lay it ontop of the pcm
Old Jan 20, 2009 | 11:37 PM
slo_neonRT's Avatar
slo_neonRT
they just lay it on top how do they keep it in place? and would that clear the hood
Old Jan 21, 2009 | 01:25 PM
spudsterier
as far as i know it will clear the hood....i would guess they might use zip ties to hold it down
Old Jan 21, 2009 | 02:24 PM
das2123's Avatar
das2123
Zip ties FTW!!!!
Old Jan 22, 2009 | 05:20 PM
slo_neonRT's Avatar
slo_neonRT
well ty all for the help
Old Jan 24, 2009 | 03:44 AM
oobical's Avatar
oobical
Originally Posted by das2123
Zip ties FTW!!!!
I have found zip ties to be quite handy, actually that is what held the muffler on my truck for 10k miles before I replaced the exhaust.
Yes, I get them at Lowe's they are for holding duct work together, and usually 24-36" in length depending on application, and being that they are designed for higher heat they work better under the hood for holding down heavier items.
I also second the PCM Mount but recommend making a bracket from an old PCM bracket from the junkyard, I got one for 5 dollars and cleaned it up nice with an air grinder and painted it to match the module.
