dohc conversion...damn cracked heads...
Old Jan 21, 2009 | 09:11 PM
dcmcguy's Avatar
dcmcguy
Question dohc conversion...damn cracked heads...
i haven't been on the forums in a while, but i had a slight misfortune today... i did a cylinder leakdown test and found out that my sohc head was cracked! SO...I just happen to have a dohc motor completely taken apart. I have the haed and cams and all, and the pcm...The pcm is what i am wondering about, I have a 96 mtx sohc...the other pcm i have is for a 98 atx dohc...after i do the dohc conversion, will my dohc pcm work? or does is have to be the same year and tranny? THANKS TO WHOEVER RESPONDS!!!
Old Jan 21, 2009 | 10:18 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Tranny dont matter, but the rev limiter wont be as high. Plus a check engine light will be on. Year does. 95\96\97-99. There is a write up on how to change the harness to work. do you have the doch harness? i
Old Jan 21, 2009 | 11:34 PM
dcmcguy's Avatar
dcmcguy
yea, i have the entire engine harness from to dohc. what is different on the pcm's from the defferent set of years?
Old Jan 22, 2009 | 02:18 PM
das2123's Avatar
das2123
95 will not work as it only has one plug. 96 controls the rad fans differently than the 97-99 pcms.
The ATX PCM will trigger the CEL for the Lockup Torque Converter.
