99 Neon turns, but won't start
Old Feb 15, 2009 | 05:25 PM
rayraydoet's Avatar
rayraydoet
Originally Posted by sabin420
Not Nssicarily...I've had this problem before...Under the hood in the relay box, there is a relay for the Auto Shut Down...You are going to want to try and jump that relay...pin 87 (not 87a-the middle pin) to pin 85...the fuel pump should turn on...if it doesn't, then you got a bad fuel pump or you are out of gas.
what if i got fuel and i no the fuel pump works then what is the problem then?
