Oil still leaking
Old Mar 13, 2005 | 09:12 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Oil still leaking
Have you checked your oil sending unit, it could be leaking from it.
Old Jan 17, 2007 | 04:13 PM
Neon_2ner's Avatar
Neon_2ner
Mine's leaking some oil too and I just finished the head gasket back in October, now I noticed that my crankcase seal needs some tightening or something along those lines. But if you said there isn't any visible on the ground and none burning, I would imagine it's getting into the coolant, and that's possible from having a bad head gasket. The repair isn't too bad on them if you have the tools and space to work on it. As we all know putting a 2.0L in that size engine bay makes it a hassle to work on.
Old Jan 17, 2007 | 07:15 PM
das2123's Avatar
das2123
ORIGINAL: Neon_2ner
The original post is almost 2 years old [8D]
