Neon Exhaust
Old Feb 7, 2009 | 11:53 PM
ottoretto's Avatar
ottoretto
Default Neon Exhaust
hello fellows, i got a question... i wanna change the exhaust system on my neon 98 soch, i got 11.1:1 compression ratio and 215lbs (on each cylinder) so if i put a 2 1/2 inchs exhaust it gonna be better?? i got a long header too!
Old Feb 8, 2009 | 08:47 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
pasesetter long tube headders have shown to have the most gains for a SOHC engine.
Old Feb 8, 2009 | 08:12 PM
ottoretto's Avatar
ottoretto
yeah i know that but my question its, if i change the exhaust pipe for another one bigger it gonna be better? u know that the sohc neon bring a 2 1/4 inches (two and a quarter inche) and i wanna put a pipe of 2 1/2 inches (two and half inches) so what u said about it?
Old Feb 8, 2009 | 08:24 PM
streetracer88's Avatar
streetracer88
yes the 2 1/2 is a good size for the exhaust i wouldnt go much bigger or you will loose power and it will back fire
Old Feb 8, 2009 | 11:58 PM
ottoretto's Avatar
ottoretto
thanks a lot bro, im aking cuz with 215 internals lbs i need som more pipe
Old Feb 9, 2009 | 12:23 AM
DOHCgarrett t3
yeah, sorry i had edited the post before but guess it did not stay.
but i added stock size is good as long as you change the SOHC mufler if you still have the stock muffler on there.
Old Feb 9, 2009 | 12:50 AM
sabin420's Avatar
sabin420
unless you turbo, you loose power going up any higher than 3, even at 3" you are risking loosing power, but 2 1/2 seems to be the magic size for the neon...all the performance exhaust kits are usually at 2 1/2.
Old Feb 9, 2009 | 09:59 AM
spudsterier's Avatar
spudsterier
2 1/4 is more then enough for the neon.....2 1/2 will be fine though...
even with a turbo on these cars, there is no need for a 3" exhaust
Old Feb 9, 2009 | 03:37 PM
das2123's Avatar
das2123
Stick with the stock size and invest the money somewhere else.
Old Feb 10, 2009 | 11:52 AM
ottoretto's Avatar
ottoretto
well i gonna get it not buy it! a friend work on a exhaust shop and he gonna give to me an 2.5" exhaust i got an HKS muffler and the entrace its 2.5" inchs... my uncle say that "whit bigger compression you have to change the exhaust system for a better perfomance" and he works with gt cars! so im cuz u know so much about neon and maybe the neon can be so kind of "exception" on the racing world!
