hey experts - got one for you - DOHC on 2nd gen?
the PCM looks the same - but its just the casing. it is only a two plug. it is not the 4 plug associated with the sentry and NGC cars. so wouldn't it be nice if I could just swap the engine harness and it would work? i cant imagine that will be the case though.
1. because I don't think the sohc pcm in the car will like my DOHC sensors
2. because I dont think my DOHC 99 PCM will like running 2nd gen gauges and other electronics.
if I could get an 00+ MTX bellhousing I think I should be able to use my t-350. this car is an auto, so I'll have to find that elsewhere.
All the 96-99 PCM's look the same, but operate the vehicle differently.
It can be done, but isn't the easiest swap. You also run into the PCM/gauge cluster problems and crank trigger problems. Also have to fab up a new side motor mount bracket.
Trending Topics
well yeah i know, but i was thinking of it more as an srt swap into a 2nd gen compared to a 2nd gen dohc swap
