as it was gettin a little warmer here this week out in indiana i went to open my sunroof and it wont open at all just makes an obnoxious clicking sound over and over and it started to open and i had to force it shut.......i was just wonderin if i was gonna need a whole new sunroof or if it is a common problem with neons or what?
the sunroof motors were built using plastic gears.....alot of times a couple of teeth will break off the gears and cause a flat spot.....that is what usually gives you grinding sound.....
