Help Please!!!
Old Feb 13, 2009 | 12:04 PM
streetracer88's Avatar
streetracer88
Default Help Please!!!
I have a 96 plymouth neon atx and when i put it to the floor it hesitates anyone know what this might be someone said a fuel filter?
Old Feb 13, 2009 | 12:25 PM
GLXRustang's Avatar
GLXRustang
Fuel injectors are getting dirty, try some concentrated gumout in the tank everytime you fill up for a week or so. A dirty fuel filter causes top end HP loss. Oh and check your plugs, fouled up plugs could cause a weak spark and a misfire.
Old Feb 13, 2009 | 02:02 PM
streetracer88
so thats what would cause it to hesitate when i put it halfway and to the floor?and i will look later at it thanks for your help
Old Feb 13, 2009 | 07:30 PM
sabin420's Avatar
sabin420
dirty throttle body, Catalytic converter going bad, bad O2 sensor, dirty injectors, dirty fuel filter, bad plugs, dirty air filter all can cause that problem.
dirty throttle body = remove and clean w/ throttle body cleaner
Catalytic converter and o2 sensor would turn on the check engine light but could cause the same problem
dirty injectors = clean like glx said
fuel filter = change
air filter = change
plugs = remove, check gap, change
any way you go, you gotta think...when you open up the throttle the engine is not getting enough of either (1) Air (2) fuel or (3) spark.
