i want it lower
Old Feb 16, 2009 | 11:30 PM
justinsanders's Avatar
justinsanders
Default i want it lower
i bought 2" lowering springs for my car and put them on but i just kinda want it a lil lower. im planning on buying the kyb gr-2's wil that lower it a lil more? if not can i maybe cut a little bit off each coil? if so where do i make the cut and how much do i cut off
Old Feb 17, 2009 | 09:19 AM
spudsterier's Avatar
spudsterier
the struts wont help lower the car...
if you cut the springs then you are going to cause alot of issues....the spring wont sit right on the spring seats anymore and you will get somne noise when turning or hitting bumps....
if the springs were new, then they still have to break in....
what kind of springs did you get?
Old Feb 17, 2009 | 10:58 AM
das2123's Avatar
das2123
DO NOT CUT YOUR SPRINGS!!!!
You want lower than 2" drop? Do you wanna punish your back that much?
Old Feb 17, 2009 | 09:43 PM
sabin420's Avatar
sabin420
You can instead of cutting your springs, raise your strut tower. It takes a lot of skill, a very good welder, and some reinforcing. I did mine and was able to drop it a total of 5" rear and 4.5" front with lowering springs.
Old Feb 17, 2009 | 11:41 PM
neoncrazy101's Avatar
neoncrazy101
I have KYB GR2's and some 1.3" lowering springs. man does it hurt going over some bumps just let me tell you that.
Old Feb 17, 2009 | 11:55 PM
sabin420's Avatar
sabin420
with my side skirts on, i got 1 5/8" clearance, 2 7/8" to the frame, frame has an extra strip of 2"x1/4" steel stock welded to the frame rails for a skid pad. 205/40/17 tires tuck completely covering 1/2" of the top of the rim in the rear and fall right under the tread of the tire in the front.
Old Feb 18, 2009 | 01:54 AM
iwalton63's Avatar
iwalton63
you have any pictures ?
Old Feb 18, 2009 | 10:39 AM
spudsterier
it could be worse....
throw on some mopar high rates and some konis adjusted to stiff....that is a rough *** ride..
Old Feb 18, 2009 | 05:52 PM
neoncrazy101
Yeah I know, I was thinking about getting some high rates but decided against it, after riding with what it has now, i am so happy i didn't lol. I can take the roughness, but its my friends who cant and they now do nothing but complain when they are in my car lol
Old Feb 18, 2009 | 09:03 PM
sabin420's Avatar
sabin420
check my photo album.
