modular and non modular
Old Feb 18, 2009 | 01:27 PM
krtrsdg0's Avatar
krtrsdg0
Angry modular and non modular
I have a 98 rt can i use a non modular clutch or does it have to be a modular
Old Feb 18, 2009 | 03:49 PM
chenzo's Avatar
chenzo
You can use a non modular, but your going to have to buy a flywheel. The non modular clutched used a flex plate that the whole assembly attached to. You will need to find either a stock flywheel, or by a lightweight aftermarket one.
Old Feb 18, 2009 | 05:12 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Your vin code will tell you which clutch it uses by where it was made. I think its the 11th digit, t or d.
Old Feb 18, 2009 | 06:46 PM
chenzo's Avatar
chenzo
I believe D is the Modular...and i cant remember the non modular...
EDIT: 11th digit. D is Belvidere, which would be modular, and T is Toluca which would be the conventional clutch.
