problems with my car please help
Old Feb 19, 2009 | 04:00 PM
reaperof_evil's Avatar
reaperof_evil
Default problems with my car please help
ok so i am getting it back saturday from the garage that replaced my water pump and head gasket the guy says it runs fine idles fine but after you run it for alittle its hard to start what could cause that? i take alot of pride in my car and would like it to run 110% i will get more news on it when i get it back
Old Feb 19, 2009 | 05:24 PM
streetracer88's Avatar
streetracer88
your starter could be goin bad?
Old Feb 19, 2009 | 05:28 PM
reaperof_evil
not sure i have a new starter on it but ill have to test it as long as it doesnt stall like it was before im not gunna worry about it
Old Feb 19, 2009 | 05:29 PM
streetracer88
ok if the starter isnt bad then check your ground wire maybe its loose
Old Feb 19, 2009 | 05:51 PM
reaperof_evil
i havent seen the car yet so i dont know exactly whats its goin yet
Old Feb 19, 2009 | 07:47 PM
Spawne32's Avatar
Spawne32
so wait a second, you took it to a mechanic to get it fixed, and now its not starting right? Tell the mechanic to check to make sure he did the timing on the car right, and check the compression on the engine, if hes any sort of competent he should know this ahead of time.
Old Feb 19, 2009 | 07:57 PM
reaperof_evil
he pulled the motor apart twice and cant find why its not starting right
Old Feb 19, 2009 | 08:02 PM
Spawne32's Avatar
Spawne32
well explain to me in greater detail what exactly its doing, if you can, theres a million different kinds of not starting right.
Old Feb 19, 2009 | 08:06 PM
reaperof_evil
i will have to let you know when i get the car back and see for myself i havent heard the car run yet just trying to find out some things to get an idea of what the problem could be
Old Feb 21, 2009 | 05:46 PM
reaperof_evil
ok so i got the car back it runs pretty damn good hit 100 like nothing but is stalling out in the lower rpms could the timing still be off alittle or what else could cause that ill have to get a video of whats its doing
