need some help with engine and tranny
Old Feb 25, 2009 | 09:21 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default need some help with engine and tranny
i posted this on the second gen side to but i figured u guys can help me also
my car is a 02 se 2.0 sohc and i was wondering..
ok, so i just got a text from a friend of mine with a neon, he may have a tranny and a engine that is off of a 96 se.... what EXACTLY is the difference between the two blocks and trannys?? trannys i know are a different gear ratio, but i need specifics... can i use a first gen block in my 02? is it just a matter of changing sensors? what will i need to get this to run propberly? or even can i get it to work properly? i can get them both very cheap..... all i want them for is to get the block built and tranny built for my car...
both cars are a sohc
need some help fast guys!!
thanks again
Old Feb 25, 2009 | 02:29 PM
I_Ride_Neon's Avatar
I_Ride_Neon
The engine will work, tranny will not work without alot of modification. You will need egr block off, and 2nd gen valve cover on it. Then just switch all sensors, hoses, clips, brackets over.
Old Feb 25, 2009 | 03:54 PM
dtjackten's Avatar
dtjackten
what is different about the trannys??? i thought they were just geared differently?
i ride, same block as a 96 eclipse??? i have one with a blown head gasket at my house?
my head has been changed from a 96 neon, i just made a block off plate, working good for the last 4 years...
Old Mar 1, 2009 | 08:53 PM
streetracer88's Avatar
streetracer88
i dont know about the tranny but i know you need a 96 computer i dont think you can use your old 1
