turbo question and oil cooler question
Old Mar 2, 2009 | 09:02 PM
rayraydoet's Avatar
rayraydoet
Default turbo question and oil cooler question
guys i got a question if the acutlator has a 6 psi spring can i boost more then 6 psi with a 6 psi spring? i got a electriconic boost controler a apexi avr c controller. so couldi set it at .45 kg/ cm2 (8 psi) and 90% duty?? or will that not work????
and i plumed up a pipe t and put a line to feed my turbo form the oil pressure snesor hole and i also feeds my oil cooler then both the turbo and the oil cooler get feed back to the oil pan. now is that safe to run the oil cooler like that feedng it from there and returnig it to the oil pan?
Old Mar 2, 2009 | 10:02 PM
70x7's Avatar
70x7
wastegate controlled only, it would open at 6psi. If you get a boost controller (like you have....but I am not familiar with that type) you would be able to run more boost.
Old Mar 2, 2009 | 10:10 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i know that they offer a oil cooler kit for the neons that is a sandwitch plate, with an external oil cooler.. that is the way that i have ever only seen it done....
i have a cooler and the sandwitch plate i will sell cheap... 65 dollars shipped.... that will include cooler and sandwitch plate.... pm me if u are interested....
Old Mar 3, 2009 | 07:07 PM
rayraydoet's Avatar
rayraydoet
what kinda of oil cooler is it? how many rows and how big? and how much would you sell the plate for with out hte cooler>? and will i be taking bto much oil; pressure away from my motor by runing the cooler from the hole on hte oil pressure switch to the oil pan? because im not returning the oil to the same line will that make me have pressure drop and maybe starve my motor of oil? if so i was thinking of puting and oil restritor in the oil line feeding it to slow down how much oil i got flowing thur it
