Can the stock engine do this
Old Mar 5, 2009 | 02:14 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Can the stock engine do this
If I run the srt-4 turbo at 4 psi. WOuld I be able to throw in a wet 35 shot? Only other mods are indy manifold, 60mm tb, udp.
Old Mar 5, 2009 | 10:02 AM
spudsterier's Avatar
spudsterier
you could, but i wouldnt reccomend it......
you can, but down the road you might run into issues with your rods and pistons
for the price of a kit, why not just run more boost?
Old Mar 5, 2009 | 12:50 PM
GLXRustang's Avatar
GLXRustang
yeah thats like 20% HP here, 20% there, when it could 40% from one source just by cranking boost up to 8psi. Without forged goodies, it could be tragic with nox
Old Mar 5, 2009 | 01:09 PM
I_Ride_Neon
Its for my show car. I was going to install it, but not use it often. Thought I would check.
Old Mar 5, 2009 | 01:23 PM
das2123's Avatar
das2123
If it's for a show car, just hook up the lines and the empty bottle.
Old Mar 5, 2009 | 01:42 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
that is what i would do das.... accually this year i am doing that... due to lack of money to finish my bottom end...
Old Mar 6, 2009 | 09:32 AM
spudsterier
i had NOS hooked up in my old red r/t...just never used it
Old Mar 6, 2009 | 12:18 PM
GLXRustang's Avatar
GLXRustang
you could always use the spray with an intercooler spray bar. If you wanted to show it off, what better way? (course I always wondered if you could hook the spray bar to the purge line of a nitrous kit.. Purge the lines of air, cool off intake charge, and later hit the juice all at the same time!)
Old Mar 6, 2009 | 12:22 PM
GLXRustang's Avatar
GLXRustang
I've got my mustang turbocharged finally, I wanted the nox just to cool off the intake charge since I don't have an intercooler yet. Running a really low shot really couldn't hurt a stock motor, neon or whatever. Wouldn't make a lot of power but would add to the cool factor of a show ride.
I'm for it for a show ride, you should go for it. (if you were in it for performance just raise the psi and save the money for forged internals)
Old Mar 6, 2009 | 12:25 PM
dtjackten's Avatar
dtjackten
u can do both intercooler and wet shot, i think it is set up in a duel stage... but i am not 100 percent, i have a intercooler spray bar but i will prolly not shoot nos into it... rather go wet shot...
