mopar computer help
Old Mar 16, 2009 | 10:20 PM
sparco_neon's Avatar
sparco_neon
Default mopar computer help
i recently bought a 97 sohc neon the guy said it has a mopar performance computer.....im trying to find out how you can tell.....
Old Mar 17, 2009 | 01:28 AM
ottoretto's Avatar
ottoretto
well acelerate the car wide open and see if u get the 7500rpms (get the engine to and rev limitation) if ur not dont have the mopar pcm, sorry but iunno another way to mesure that
Old Mar 17, 2009 | 01:21 PM
sparco_neon
thanks i will try that
Old Mar 17, 2009 | 07:20 PM
vabear's Avatar
vabear
Default Mopar pcm
On my '98 the MOPAR performance PCM has a decal attached to it that lists it as CARB certified.
Old Mar 17, 2009 | 09:27 PM
sabin420's Avatar
sabin420
Mine has a Decal on it that says MOPAR Performance. It should be on the top of the computer. The Stock just had some numbers stamped into the case.
Old Mar 17, 2009 | 11:50 PM
spudsterier's Avatar
spudsterier
most mopar perf. pcms have the carb exempt sticker on the bottom
Old Mar 18, 2009 | 02:11 PM
sparco_neon
thanks for all the help guys.....im new to neons so i dont know what carb except means but i do know i tryed yesterday and couldnt get my car to hit a rev limit
Old Mar 19, 2009 | 11:26 PM
sabin420's Avatar
sabin420
my car wouldn't hit the rev limit until I put an extreme cam in it. if your rev limiter is 6200, then you got the stock computer...w/o power in your motor, you won't be able to hit the 7800 rpm mark Mopar computer gives you. the engine just can't mechanically turn that many rpm's
Old Mar 20, 2009 | 09:36 AM
GLXRustang's Avatar
GLXRustang
In the automatic DOHC it shifts at 6500 (in D), but I've never experienced a rev limit at 6500 when I put in 1 or 2. Does the DOHC neon motor make power to 7500 rpm? Or does it peak around 6500?
Old Mar 20, 2009 | 01:55 PM
sparco_neon
whats a good cam i can run with out having to do a bunch of stuff to run it
