DOHC and SOHC pcm??
Old Mar 26, 2009 | 08:24 PM
97 neon's Avatar
97 neon
Default DOHC and SOHC pcm??
I was wondering if i took the computer out of a DOHC and put it in a SOHC if it would make a difference or if it would even work.
Old Mar 26, 2009 | 11:23 PM
sabin420's Avatar
sabin420
I don't know...It might work...the sensors are different for the cam...but it gives the same signal to the pcm I believe. So, I don't see any reason why it wouldn't.
Old Mar 27, 2009 | 09:55 PM
97 neon's Avatar
97 neon
I have one but im kind of affraid it will mess something. do you think it would hurt anything?
Old Mar 28, 2009 | 05:53 AM
Captansavaho's Avatar
Captansavaho
the only thing it will hurt is your gas mileage
Old Mar 30, 2009 | 11:14 AM
ottoretto's Avatar
ottoretto
its the same bro, the car well improve a lil!
Old Mar 30, 2009 | 09:05 PM
97 neon's Avatar
97 neon
thanks guys i'll try it out.
Old Apr 2, 2009 | 02:25 PM
Altima_wb's Avatar
Altima_wb
its been done a few times... gives a higer rev limit, 7200 vrs the stock 6750 on the sohc which is kinda nice... deff a worth while mod if you race or have other mods done... its a poor mans way to get a higher rev limit with out spending big bucks on an aftermarket ecu... although the best way to go is with an aftermarket ecu... this is just a step better then stock...
Old Apr 3, 2009 | 01:09 AM
12 volt's Avatar
12 volt
also makes u run rich
Old Apr 3, 2009 | 04:11 AM
Altima_wb's Avatar
Altima_wb
yes it will make you run rich but of you have a fair amount of mods its probably a good thing to have a bit more fuel anyway which is probably another reason why people notice an increase in power when the swap to the dohc pcm....
Old Apr 18, 2009 | 03:54 PM
9R/T.4door8's Avatar
9R/T.4door8
does the mopar pcm allow the engine to rev higher than stock? i can currently rev the engine to 7500rpms with no problems at all.....is that ok for the engine? (no i dont red line the engine daily)
