Camshaft Sensor
Old Mar 29, 2009 | 06:08 PM
ottoretto's Avatar
ottoretto
Default Camshaft Sensor
Hello fellows, iunno how the camshaft sensor works 1g neon!, i want to know that... and the function of each cable... thanks! 1g neon!
Old Mar 29, 2009 | 06:14 PM
sabin420's Avatar
sabin420
you got 3 wires...power, signal, ground. the cam shaft has 4 magnets on it and the sensor has 4. every time the magnets line up, it sends a signal to the pcm telling it that it's in a certain position. working with the crank position sensor, it tells the pcm when to inject fuel and when to fire the spark plugs.
Old Mar 29, 2009 | 10:34 PM
ottoretto's Avatar
ottoretto
ohhh thanks! and the signal with how many volts it works?
Old Mar 30, 2009 | 10:56 PM
sabin420's Avatar
sabin420
ummm...i would think 12 VDC cause that's what the car runs on.
Old Mar 30, 2009 | 11:17 PM
ottoretto's Avatar
ottoretto
well iunno much, but i dont think that, its so much for a sensor! if u know anything else please tell me thank!
