How to replace temp sensor
Old Apr 3, 2009 | 11:33 PM
lexxerd's Avatar
lexxerd
Default How to replace temp sensor
I looked through the FAQ and through my Haynes manual but neither specifically show how to get the part off and install the new one. With the setup everything is so close and tight I cant get a ratchet in there. Anyone comes across this problem? Only thing I can think of is some long needle nose pliers but how tight should this thing be in there? Thanks in advance! Everyones been very helpful with my other posts.
EDIT: this is for a 98 DOHC
Old Apr 4, 2009 | 01:05 PM
12 volt's Avatar
12 volt
i guess your talking about the coolant temp sensor?
http://i37.photobucket.com/albums/e6...SensorDOHC.jpg
in this case remove the connetor and use a socket with a long extenson so you can fit the ratchet on.
Old Apr 4, 2009 | 07:07 PM
ldiablo233's Avatar
ldiablo233
For the DOHC should be the same as single, just easier location. Its one of 18,19, or 21mm long socket. I believe its 18.
Old Apr 4, 2009 | 08:05 PM
lexxerd's Avatar
lexxerd
Thanks, got it taken care of.
