cam timing
Old Apr 3, 2009 | 11:40 PM
rayraydoet's Avatar
rayraydoet
Default cam timing
hey guys i got hr 259 cam from comp and my motor is sohc i want to get the best powr out of it when the turbo is kicked in should i dvance the cam timing or retard it? its got and adjustibe pully. what do you guys think?
Old Apr 4, 2009 | 12:06 AM
ottoretto's Avatar
ottoretto
retard it! its the best for a turbo! i think like 3 degrees but if u got a adjustable pulley try retarding the car and look when its on the top, do not advance, cuz u gonna gain a lil of compression and that what we dont want when we are turbo!
Old Apr 4, 2009 | 08:51 AM
sabin420's Avatar
sabin420
retard the cam, advance the spark...that's the basic rule for tuning on any car.
Old Apr 4, 2009 | 12:47 PM
12 volt's Avatar
12 volt
you really shouldent mess with cam timing unless your dyno tuning. Street tuning buy the butt dyno isnt that accurate.
Old Apr 4, 2009 | 02:03 PM
ottoretto's Avatar
ottoretto
but how he can do to advance the spark i got a n/a neon but iunno how to!!
Old Apr 5, 2009 | 08:18 AM
sabin420's Avatar
sabin420
Megasquirt or performance computer are the only ways on a neon.
Old Apr 5, 2009 | 10:10 AM
rayraydoet's Avatar
rayraydoet
my plz r 500 and all my gauges will help me tune my cam. i got everything i got afr meter iat sensor readings egt readings map reading knock scope, colant temp everything. its all hooked up to my labtop so i can monitor everything and record iit. what im guna do is is 1 degree at atime and im guna do a 1/4 mile run and record all my things then go over everything make sure my afr is 12.3 12.5
