Longer throttle cable?
Old Apr 4, 2009 | 07:03 PM
ldiablo233's Avatar
ldiablo233
Default Longer throttle cable?
I need a longer throttle cable to reach the TB on my ghettoblaster manifold. I would just clamp some extra metal wire in between the throttle cable, but I think it would hit the plastic piece on the TB shaft, or the bracket that holds the TB cable in place. I only need like 4 inches. Anyone know what I can do, or a car that has one that will fit onto a neon?
Old Apr 4, 2009 | 07:32 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Some neons come with longer throttle cables. Go junkyard shopping. I dont remember what kind of neon they come off of, but I think its atx's.
Old Apr 4, 2009 | 08:57 PM
ldiablo233's Avatar
ldiablo233
Mine was originally an atx so its probably the longest. but I'll check at the JY monday.
Old Apr 4, 2009 | 11:50 PM
I_Ride_Neon
The longer of the two is really really long. You will know the difference. Maybe on 95's, or maybe on cars with cruise control. I am not sure where to find them.
Old Apr 5, 2009 | 11:07 AM
ldiablo233's Avatar
ldiablo233
Lol it had cruise too. There is a 95 there so I'll check.
Old Apr 6, 2009 | 09:41 AM
spudsterier's Avatar
spudsterier
all 4 of my old 98 r/t's had the really long throttle cable...
i think most of the 98-99 5-speeds neons had it...
you will deffinately notice the difference because the cable is about 5 feet longer then yours
Old Apr 6, 2009 | 01:54 PM
das2123's Avatar
das2123
I never understood nor found the reason behind the longer throttle cable. But it is DEFINITELY longer.
My best guess would be a production shortage of of them and used one from another vehicle, maybe the Stratus or something like that.
Old Apr 6, 2009 | 03:41 PM
ldiablo233's Avatar
ldiablo233
Couldn't find any 1st gens or stratus's with longer ones but I got one from a 2nd gen that will fit the TB piece, and should have no big issue fitting the TB bracket/pedal when the time comes.
Old Apr 7, 2009 | 12:42 AM
spudsterier
you could probally pull another neon up infront of the other and use the throttle cable from one car to run the other car
Old Apr 22, 2009 | 07:35 PM
b1mmuo27's Avatar
b1mmuo27
Just reading this post & myself am looking for a 5 foot throttle cable that would work on a 94 5.2L MPI engine. I did a swap from my 74 Winnebago 318-3 to the 94 MPI. Is the cable you mention 5 feet long? Thanks
