96 Neon stalls after running
Old Apr 23, 2009 | 08:55 PM
Nd97045's Avatar
Nd97045
Default 96 Neon stalls after running
I've got a 96 Neon and it will run for around 2-3 miles, or 15 minutes and then stop running, and will not start again after it stalls unless we(Father and I) wait awhile. If we starting fluid into the air cleaner it runs briefly, but stalls shortly after. Any feedback would be much appreciated. Thanks.
Old Apr 23, 2009 | 09:20 PM
vabear's Avatar
vabear
Default Stalls after 15 minutes
Same thing happened on my '98 and it was the crankshaft position sensor. Will she code out (key dance), do it right after she stalls, in my case it would not code out with a cold engine.
Old Apr 23, 2009 | 10:22 PM
sabin420's Avatar
sabin420
Does it have fuel pressure? in the center of the fuel rail is a place to put a gauge. You can push down on the pin w/ a screwdriver or something small and see if it has pressure? If so, check for spark...make sure the spark plugs arn't fowled out and make sure the coil pack is firing. Air, fuel, compression, and spark makes the motor run...figure out which one you don't have and you can find your problem.
Old Apr 24, 2009 | 06:33 PM
Nd97045's Avatar
Nd97045
We just checked the pressure, it was showing 50 PSI.. Is that low? And we've already replaced the coil pack.
Old Apr 25, 2009 | 12:07 AM
ryleynoyes's Avatar
ryleynoyes
check to make sure you have good signals from your sensors. it sounds like the auto shutdown relay. in my case, it ended up being a bad ground on my MSD ignition adapter, which gave it a weak signal from, i think, the crank position sensor.
Old Apr 27, 2009 | 04:47 PM
Undercooked emu's Avatar
Undercooked emu
Definitely sounds like a bad crank sensor...pretty common problem for most Neons.
