wont stay running runs VERY poorly
Old Apr 25, 2009 | 10:07 PM
contact148's Avatar
contact148
Default wont stay running runs VERY poorly SOLVED!!
1995 4 door neon auto tranny 220, KM
check engine light wont work (so no idea about codes) NOT the bulb
car backfires and sounds like a 2 stroke engine and wont run unless I push gas peddle in 1/2 way
now the EGR seloniod with the key ON engine OFF makes a rapid clicking sound (2nd one ive tried so not the seloniod)
I put a test light/probe on the neg battery post and clipped the end to the cable then i removed the cable and the light lit (this was neg side ONLY) key was on engine off
so this to me says i have a grounded out wire somewhere??
ive moved around as many wires as i could and no change
I also disconected several sensors and no change
any ideas and dose anyone have the factory wireing diagrams???
Old Apr 26, 2009 | 11:21 PM
ldiablo233's Avatar
ldiablo233
Well run it with all spark plug wires in, then remove one at a time and see if it bogs. If theres no change when removing certain ones then it could be the wires/coil pack for that cylinder(s).Also,autoparts stores can do free OBDII scans,it should still scan even with your messed up CEL.
Old Apr 27, 2009 | 10:15 PM
berretta96's Avatar
berretta96
unplug your EGR, your car will run without it.
it sounds like a bad coil pack. Every bad coil pack I've seen on neons does this same thing before being replaced.
Old Apr 28, 2009 | 05:29 PM
contact148's Avatar
contact148
well i metered my coil with a fluke meter today
primary i got
left side pin .o8 right side pin .06
secondary tower 1-4 11.80 tower 2-3 11.63
this is a 95 neon
those numbers tell you anything??
Old Apr 28, 2009 | 08:05 PM
contact148's Avatar
contact148
well tonight i played somemore
I found the problem i think
when i turn the key ON engine OFF the fuel pump does not run
when cranking or engine running the pump does run
BUT the fuel pump relay and the auto shutdown relay are clicking like mad when cranking or engine running
all fuses are good
I metered the fuel pump wires and NO power to it when key is on so its not the pump....
Old Apr 28, 2009 | 10:39 PM
sabin420's Avatar
sabin420
It could also be you got the wires backwards. The car backfiring is a usual cause of this.
Also, check the wires to your o2 sensors. I've had a wire w/ broken insulation do this to me. Check at the harnesses too...that's a common place for the insulation to break or strip back. That could be causing your relay's to click.
Old May 3, 2009 | 09:36 AM
contact148's Avatar
contact148
ok turns out it was main computer PCM in the engine
as soon as i plugged in a new one (from the bone yard) car started and ran perfectly
I got a real new looking one that was refurbished in 2006 part # R4874166 OR R4874156 hard to read was out of a 95 DOHC AT
mine is a 95 SOHC AT
