PCM conector repair help!!
Old Apr 30, 2009 | 07:48 AM
contact148's Avatar
contact148
Default PCM conector repair help!!
ok got my car semi running found several wires grounded out
NOW I have found that the engines running changes if I wiggle the wires below this is AT the connecter on the harness side at the PCM
Purple wire
purple with black stripe
and yellow black stripe
so how/can that connectoer be opened and repaired
OR will I have to get another and splice like 60 wires......
Old May 4, 2009 | 02:12 PM
GLXRustang's Avatar
GLXRustang
I have the skematic in my album if you want to double check. Purple wire and Yellow blk stripe wire goes to idle speed control motor which will effect how your car runs if bad. The other wire I can't find going from the pcm.
The pins should be able to be removed and replaced out of the pcm connector without cutting and splicing the whole thing.
Old May 9, 2009 | 11:51 AM
Jyro's Avatar
Jyro
What year and engine
Old May 9, 2009 | 11:52 AM
Jyro's Avatar
Jyro
also witch connector black or grey
Old May 9, 2009 | 11:57 AM
Jyro's Avatar
Jyro
ok on my 99 sohc :
purple wire = idle air control number 4 driver
purple w/ black stripe = not one
(but there is a purple w/light green stripe = battery temp sig)
yellow w/ black stripe = idle air control number 2 driver
Old May 9, 2009 | 11:58 AM
Jyro's Avatar
Jyro
i.a.c motor is more that like the problem, but it could be a driver problem within the pcm.
