Old fuel filter??
Old May 19, 2009 | 12:55 AM
ldiablo233's Avatar
ldiablo233
Default Old fuel filter??
Whats the average change for these cause mine looked super old when I was under there 2 months ago and since I have poor mileage(oil leak, but still TOO poor) I was thinking of getting one from advanced, there only 9 bucks. If I replace it, anything to worry about/hard to do??
Old May 19, 2009 | 07:36 PM
vabear's Avatar
vabear
Default Fuel Filter
As the fuel filter is part of the fuel pump module and located in the tank, how did you check it out? Bottom line is there is no time frame for changing the filter.
Old May 20, 2009 | 12:10 AM
ldiablo233's Avatar
ldiablo233
Really? Whats that little thing that the fuel lines go into from the fuel pump, its mounted on the underside of the car?
Old May 20, 2009 | 08:39 AM
vabear's Avatar
vabear
Default Fuel Filter
OK, if you have a 1995 model then it does have the replaceable filter, 30,000 mile recommended change.
Old May 20, 2009 | 12:01 PM
ldiablo233's Avatar
ldiablo233
Its a 98. I'll take a look maybe it has a 95 part in it.
Old May 20, 2009 | 03:36 PM
Altima_wb's Avatar
Altima_wb
there are a few models that seem to have a filter same as the 95... my repair manual says only the 95s but most parts stores show the fuel filter up to the 99 model year... and its deff probably a good thing to change it... if it looks nasty on the outside then the inside is 100 times worse...
Old May 21, 2009 | 12:24 PM
ldiablo233's Avatar
ldiablo233
Mine has a "fuel Accumulator", that says "do not service". Theres two rubber lines going form the fuel pump into it.
