Motor Mount Inserts
Old Mar 13, 2005 | 10:54 PM
RayDog26's Avatar
RayDog26
Default Motor Mount Inserts
My car has some bad motor mounts cuz every time i hit the pedal it rocks like crazy and i get the power delay... so come spring(when ever that might be) im gonna get some motor mount inserts. im not sure how hard they are to put in on this car so i thought i might ask. my bros car was easy to do so i hope mine are the same.
i was planning on getting these:
http://store.summitracing.com/partde...=KeywordSearch
Old Mar 13, 2005 | 10:55 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Motor Mount Inserts
Its not that hard, I've done it to mine already. Took me maybe 30 minutes.
Old Mar 13, 2005 | 11:01 PM
RayDog26's Avatar
RayDog26
do you know where they are located. i took a quick glance and seen that one is on the passenger side but i didn't go under to see where the others were.
Old Mar 14, 2005 | 12:23 AM
casper's Avatar
casper
They are not that hard to put in. 30 minutes at most.
Old Mar 14, 2005 | 05:14 AM
LoNeWuLf's Avatar
LoNeWuLf
Agreed.
I did this.. There is another in the front of the vehicle maybe right in front of the fan.
Old Mar 14, 2005 | 07:21 AM
71RoadRunner's Avatar
71RoadRunner
The inserts are fairly easy to put in, but you may need to support the engine with a jack to keep it in place while you do this.
Old Mar 14, 2005 | 12:26 PM
casper's Avatar
casper
There are techincally 4, one in the front of the car on the front support to the motor and trans, one on either side on the top that just support the motor, and a bobble strut on the back side of that motor that takes the torque.
Old Mar 23, 2005 | 02:14 PM
jimmasterK's Avatar
jimmasterK
Unless I'm mistaken, the bobble strut is only on the manuals. I'm also wondering about motor mount inserts because I have some but haven't got around to putting them in yet. I asked on a neon forum for help but didn't get too awful much in the area I was looking for it. I know exactly where the mount on the passenger's side is, and I know exactly where the mount on the front is. It's the transmission mount that is confounding me. I was told you have to take off the wheel and go in through the fender, and removing the battery will help you get to it easier. So if anyone here can help me out on this and tell me what the easiest way to get to each bolt on each mount is, I would appreciate it.
Also, something no one mentioned on here that the other forum was able to help me with, the passenger's side mount will not stay in. It has the tendancy to slide out. I was advised to get a fender washer with an ID of 1/2" and an OD of 2-2 1/2 " and that will keep her in place just dandy.
Old Mar 23, 2005 | 06:31 PM
chud298's Avatar
chud298
I'm just wondering, because I'm putting mine in on sunday, why would it slide out. I want to make sure everything is done right soo...
Old Mar 24, 2005 | 06:42 AM
casper's Avatar
casper
I don't know about a ATX, I thought they were the same, but. 1- on the front by the radiator. 2- on the passenger side on the top side of the motor, by the fender. 3- Drivers side by the radiator. 4- Bottom of the motor, rear in between the motor and trans, aka the bobble strut, it looks like a small shock.
