Dying at idle, need some ideas!
Old May 26, 2009 | 11:20 PM
sabin420's Avatar
sabin420
Yes, there are codes that won't throw the light on. Could I also suggest maybe a vaccum leak at the brake booster? or will that turn the light on? I don't know, mine's backwards...if the check engine light goes off, it's about to break down on me.
If I'm not mistaking, wouldn't the fuel pump problem be more noticeable at higher rpm's demanding more fuel? Only a pressure problem, like too much could cause it to sputter and stall at Idle. A fix for the egr would be a blockoff plate...won't throw any codes either if done properly. www.modernperformance.com sells them too.
Old May 26, 2009 | 11:44 PM
1st Gen's Avatar
1st Gen
A leak at the brake booster would show in the form of a soft brake pedal.
I've been wondering about dirty injectors since this car has a poor filter system.
When I go to the j/y this week, I'm going to grab a spare TPS, EGR, and PCV to do some diagnostics. I'll post back when I know but I have to get the car back together and running before I can do anything on this front.
Old May 27, 2009 | 11:05 PM
9R/T.4door8's Avatar
9R/T.4door8
your *** talking is possible...lol check for stored codes, the cel wont always kick on for evrything......
Old May 31, 2009 | 07:49 PM
kabuk1's Avatar
kabuk1
well i think the mystery may be solved guys. i havent had a chance to do the leak down test yet due to lack of finances, but today as i was driving down the highway the engine light came on. the car was driving just fine though so i got it home & checked the codes. 32 & 24. did some research & found that its the throttle position sensor & the egr valve.
i just have one question about the tps- how crucial is it to replace it asap? would a good cleaning help it? cause im super broke right now.
Old Jun 1, 2009 | 06:29 PM
1st Gen's Avatar
1st Gen
What kind of car do you have? If it's a SOHC, they're a dime a dozen at the j/y. Just go and snag another one. If it's a DOHC, I grabbed one while I was at the j/y today and would be willing to sell it to you for $5+shipping. I'm buying a new one which will run about $90.
Old Jun 1, 2009 | 07:12 PM
kabuk1's Avatar
kabuk1
its a SOHC. ive got a junkyard trip planned for wednesday already, thanks though
Old Jun 4, 2009 | 02:38 PM
1st Gen's Avatar
1st Gen
I swapped out both the TPS and EGR so I don't know which one it was.
The stalling problem is gone now though. Good riddance too.
Oh yea, you'll need a torx wrench to remove the SOHC version. You'll be out of luck if you go to the j/y without one.
Old Jun 4, 2009 | 07:24 PM
rreyes258's Avatar
rreyes258
Wink
i had the same problem with my 95 2.0 sohc w/ auto. i had no codes and good fuel psi as well as a new pvc and still stalled at the stop sign..... found out that it ran great after i pulled the purge nipple line off the TB. i then narrowed it down to the TB or the purge valve or solonoid. i replaced the TB w/ a used clean one and it runs SWEET.
